Re: Value of IHC 766 = ?
Posted by Hugh MacKay on March 19, 2005 at 22:10:58 from (216.208.58.131):
In Reply to: Value of IHC 766 = ? posted by Mark B in TN on March 19, 2005 at 17:25:58:
Mark: From what you describe $7,500. would be tops if diesel, about $4,000. if gas. Then I'd knock another $1,000. for those 34" tires and wheels. 38" will make a tractor out of it.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
