Re: f-4 mag question
Posted by Nebraska Cowman on March 21, 2005 at 07:02:29 from (65.162.146.65):
In Reply to: f-4 mag question posted by Wes in PA on March 20, 2005 at 18:47:42:
Probably, that same mag was made in a 6 cylinder version too and your disk could be from one of those. Yes the difference would change the mag timing but I suppose you could compensate by putting the gear in a different notch. Sure might be confusing to someone else later on though. I think I have som NOS disks if you need one. On the other hand the brass is quite thick and you can sand it smooth again. I use a sheet of sandpaper on a flat surface and just keep turning the piece in my hand to keep it true and sand away. the disk and brass are soft and you can remove quite a bit of material in a hurry.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
