M transmission pilot bearing keeps failing
Posted by zooeyhall on March 21, 2005 at 08:44:57 from (204.26.68.3):
I am having trouble with the little pilot bearing in my M transmission. This is the small bearing that bolts onto the end of the main transmission shaft, the one that the gears move on when you shift. It runs inside the tranmission drive shaft that comes in from the engine. I replaced the bearing about 2 years ago, after it failed, and now it has done the same thing again.
This is a standard M tractor, nothing special added to the transmission. Is this a problem area on M tractors? I use this M for quite alot of discing on 160 acres. I very much appreciate any insight that anyone has to offer on this problem!
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject:
