Re: ether injection on 1086
Posted by chadd on March 24, 2005 at 08:47:45 from (155.92.30.248):
In Reply to: Re: ether injection on 1086 posted by fry on March 24, 2005 at 07:42:21:
Well, my guess is that the starting compression is low, the timing is off, or the injectors aren't releasing the fuel at the proper pressure. The low compression could be caused by a cracked or damaged compression ring, poorly seating valves, or even a leak through an injector fitting. I guess as long as it runs and does its job, it doesn't really need to be fixed, but I would be a little hesitant to run a diesel that needs ether to start it in summer. If it were fixed now, it would probably be a lot cheaper than later after the ether has taken its toll. I am sure a lot of other guys on the forum can give you some more specific info. Good luck!
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
