Re: Best Penetrating Oil?
Posted by Michael Soldan on March 24, 2005 at 15:52:27 from (66.203.172.221):
In Reply to: Best Penetrating Oil? posted by Nathan in Texas on March 24, 2005 at 13:17:21:
I am no expert and my opinion carries no more weight or value than anyone else. But, I have been told that WD40 is really a Water Displacement formula and although it has lubricant qualities it does not perform for any period of time. I used to use it on door hinges on the vehicles and I was finding that two or three days later I was hearing squeeks again. WD40 dries out quickly and is a poor choice as a lubricant. It works very well for displacing moisture..spray a wet distributor cap, wipe it off and it will fire, it is a good starting fluid and will fire a small engine when it is flooded but it does not have sustained lubricating qualities like a good petroleum based lubricant.In our shop we used a product called "MOVE_IT" which sprayed on would loosen siezed bolts overnight and we swore by it. There are lots of good penetrating products on the market but WD 40 isn't one of them in my opinion. If you are happy with it by all means use it but it has not satisfied my requirements. Mike in Exeter Ontario
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
