Re: Best Penetrating Oil?
Posted by Opa A on March 24, 2005 at 18:03:12 from (161.184.44.102):
In Reply to: Best Penetrating Oil? posted by Nathan in Texas on March 24, 2005 at 13:17:21:
I've used at least a dozen products, haven't found any difference.
Heat always works, but heat the bolt etc. not the casting.
Had a coworker in JD dealership heat a block to get a broken oil pressure sender fitting out. Got the fitting out, installed a new fitting and fired her up. Then saw oil comming through the casting, yep, cracked the block. Dealership ate the cost of switching blocks in an 8650, $$$$$$$.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
