Re: 300 12 volt conv question.
Posted by Bob M on March 26, 2005 at 17:07:36 from (69.201.120.79):
In Reply to: 300 12 volt conv question. posted by Kelly C on March 26, 2005 at 16:37:45:
The diode is to prevent the #1 aux terminal on the alternator from backfeeding the ignition coil when you turn off the ignition switch. Without the diode the engine will not shut down when you turn off the ignition.
Alternatively you can substitute a small lamp rated at 200 ma or so (or an equivalent series resistance) for the diode. This will limit the backflow current to less than that required to fire the coil. And the lamp will light if the alternator is not charging while the ignition is on - same as the dash idiot light on your car/truck.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
