Re: 400 Farmall Steering part II
Posted by chadd on March 29, 2005 at 13:28:08 from (155.92.30.248):
In Reply to: 400 Farmall Steering part II posted by grubby on March 29, 2005 at 07:00:15:
I don't know about a 400, but on the later tractors such as the 806, there was a check valve that would close whenever the pressure dropped in the steering system, allowing the steering to continue working. In your case, this probably broke or is stuck open. The other option is the hydraulic filter bypass, which I also don't know if your tractor has. When the filter gets clogged, it opens, allowing the fluid to bypass. I hope this helps, but, I don't know if any of it applies to your problem.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
