Re: Change M generator to alternator Help!!!!!!
Posted by Hayfarmer on March 30, 2005 at 19:54:41 from (12.160.163.177):
In Reply to: Re: Change M generator to alternator Help!!!!!! posted by Bill Hill on March 30, 2005 at 19:36:19:
IN the archives of this site Bob M has a great wiring diagram for the 12 volt alternator. You mut have the 3 wire alternator instead of 1 wire. I would get one of the plastic plugs that goes into the spot with the 2 male spade connectors. You can pick up one at a parts car parts place. I didn't hve one on mine at first, used the spade connectors, then I shorted one and put in a new regulator. If your setup is currently 12 volts, and if you have a 12 voldt, negative ground electronic ignition you shouldn't need the resister. If you still have a 6 volt positive ground setup with electronic ignition, you will have a problem as you can not reverse the polarity on them. The #1 wire from the alternator goes to your amp guage I believe. IN that wire you need a small resister, a diode or a light bulb in order to keep it from back feeding when you try to turn your tractor off.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
