Re: Help with 1206 clutch pedal
Posted by K.B.-826 on March 30, 2005 at 20:47:55 from (68.115.110.249):
In Reply to: Help with 1206 clutch pedal posted by ol_timer on March 30, 2005 at 18:11:20:
Tractor vet is right, gotta pull the whole rockshaft housing/rear end cover assembly. Not a bad job, just remove the platform, remove the seat and use the seat mounting bolt holes to attach a chain. Check an I&T manual to familiarize yourself with the draft control linkage so you don't damage it and get it back together right. The pedal is probably worn too, you'll probably need to have it drilled out and have a bushing installed. Replace the pin and have it fit to the new bushing. Make sure to get a grease fitting back in there when you're all done.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
