Re: 7130 RPM TROUBLE
Posted by the tractor vet on March 30, 2005 at 21:21:58 from (4.124.95.246):
In Reply to: 7130 RPM TROUBLE posted by Sprowcow on March 30, 2005 at 21:07:41:
Well i guess that your pump man realy does not know that pump as well as he thinks now like i said before i am not the expert on the 8.3 cummins but with the fluttering on throttel up it sounds like plunger problems and it could be a bit out of time , now one thing that you should be aware of is that on cummins engines valve adjustment is critical this can affect power and fuel i know on the 5.9 those i know it will make a big differance. . Don't know where you are from but go talk to a Real Cummins dealer or have them look at it . If i had a book on one it would not take me long to figure it out.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
