Splitting a 5288
Posted by WFE on March 31, 2005 at 05:57:54 from (24.177.100.105):
5288 needs a complete overhaul. I don't have any books/manuals for this tractor yet, but where do you split this tractor? I see between the transmission housing and the front motor frame rails is sandwiched a plate of some kind. Do I split before/in front of the plate or does the plate go with the motor? Any special tricks or secrets to know before I separate this animal? I assume that there will be at least a torsional dampener attached to the flywheel splined to the trans. input shaft. If so, how does one get that to line up again when putting back together? I generally work on Olivers and Whites, so splitting a tractor is new territory.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject:
