Re: Rebuilt Carb on 300 U Leaking Gas
Posted by Joe A. on April 01, 2005 at 18:41:43 from (137.170.133.4):
In Reply to: Re: Rebuilt Carb on 300 U Leaking Gas posted by Ron Smith on April 01, 2005 at 14:55:18:
Usually, if the governor shaft is not connected correctly, the tractor will run wide open, ready for liftoff. The float might be stuck halfway up, not letting the float open completely, starving the engine during throttling up.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
