Re: M Clutch Issues?
Posted by John M on April 02, 2005 at 18:36:50 from (64.53.74.20):
In Reply to: M Clutch Issues? posted by Nathan in Texas on April 02, 2005 at 18:06:26:
Would it stop moving if you had the tractor in gear and moving if you pushed in the clutch?If not then one of the three adjusting fingers has come loose,they are held in with a pin that has a cotter key on it and if the pin comes out,the clutch will act just as you describe.I had that happen oncec and I was headed for a tree,Thankfully I was able to cut it off fast enough to keep from hitting the tree.
Post a Followup
