Re: IH 350 Utility shifting problem
Posted by migraine on April 03, 2005 at 16:34:19 from (24.18.75.6):
In Reply to: IH 350 Utility shifting problem posted by Don Wells on April 03, 2005 at 15:59:27:
If the tractor is equipped with a TA (Torque Amplifier) sounds like it is out of adjustment and not releasing when you depress the clutch. You can try to pull the TA lever back to the low side setting before shifting . If that releases the pressure to allow shifting, then some adjuustment is in order. If it has no TA then the clutch and throw out bearing must be getting dry or soft in the pressure plate. Migraine
Post a Followup
