Re: Lift all pump
Posted by Aces on April 04, 2005 at 08:12:29 from (67.0.8.209):
In Reply to: Lift all pump posted by Zach Perry on April 04, 2005 at 07:20:46:
Zach The drive on the old belly pump is threaded on so don't try and press. You may have to put in vice with blocks of wood so you don't harm the gear then use a hammer and soft punch to brake the drive loose. Should be right hand thread, some times very tight. No key on pump or on the driver on the tranny.
Post a Followup
