Re: Lift all pump
Posted by Zach Perry on April 04, 2005 at 09:33:36 from (69.15.144.18):
In Reply to: Re: Lift all pump posted by Aces on April 04, 2005 at 08:12:29:
So as I under stand it the drive for the pump with the 1/2 inch slot in it (same slot the removable drive shaft between the trans and lift pump uses) is threaded onto the shaft. Am I correct in this statment.
Post a Followup
