Re: Still Oil pressure problems
Posted by MN Charlie on April 04, 2005 at 14:54:23 from (134.29.138.50):
In Reply to: Still Oil pressure problems posted by Darin on April 04, 2005 at 10:02:41:
I"m in the process of rebuilding a Farmall C and when I had it apart I check the oil pump out very carefully and found that the bottom cover was warped and the little thin gasket was blowen out. Remachined the cover flat and reinstalled. I had it running last night for an hour and still have good oil pressure with 10W30 oil. I need to get it hooked to the dyno for a good break-in, and a final check. I"m sure I took care of the problem.
Post a Followup
