Re: M Clutch Issues?
Posted by CNKS on April 04, 2005 at 18:23:11 from (204.249.178.138):
In Reply to: Re: M Clutch Issues? posted by Nathan in Texas on April 02, 2005 at 19:00:59:
If you push the clutch in, shift to neutral, let it out, then push it in and shift without waiting a few seconds the gears will grind. The way you were using it, you weren't doing that--In one post below, the oil getting thinner with heat and causing problems was mentioned. As hard as you were using the tractor (in a way you were abusing it), that could be the problem. Also as mentioned, on a hill those gears are under a lot of pressure, shifting in those conditions would be harder. My advice is not to use it so hard, don't back up so far, etc. Your pto and transmission were not made to handle brush.
Post a Followup
