Re: Still Oil pressure problems
Posted by BillWV on April 05, 2005 at 05:42:20 from (129.71.139.23):
In Reply to: Still Oil pressure problems posted by Darin on April 04, 2005 at 10:02:41:
I had the same experience as MN Charlie. Not only was the bottom warped, and gasket blown out, but one of the bolts had dropped out (and was in the bottom of the pan).
I trued up the bottom the best I could on a flat piece of steel with sandpaper on top, and checked end clearance with plastigage. I needed two of the thin paper gaskets to get the right clearance.
Now the oil pressure is much better.
Good luck,
Bill
Post a Followup
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
