Re: Possible to replace condensor without removing
Posted by MagMan on April 05, 2005 at 17:23:15 from (152.163.101.13):
In Reply to: Possible to replace condensor without removing mag posted by Bongo on April 05, 2005 at 15:57:45:
Yes Bongo it can be done it exsplains the precedure in the GS service manual. If you are afraid to take the mag of pull the top cover off unscrew the Nut Stud with a 7/16 wrench that the condenser bolts to take the condenser hold down bolt out now you take a pic and carefully remove the outer backelight washer then push the condenser back against the cover on the back side. Then pick the inner bakelight washer out it has a flat side that when you restall goes toward the front lets say middle would be 3:00 your condenser should slide right out the hole on that side now. It is a lot easier to mark the mag and just dont turn anything over then reinstall. But either way it will be done. MagMan
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
