Re: CMW rings
Posted by janicholson on April 06, 2005 at 15:07:38 from (199.17.6.175):
In Reply to: CMW rings posted by MagnumBoy on April 05, 2005 at 20:55:21:
Rings have only two real important issues and one not too important decision. The end gap of the new ring must be to spec. when installed in the smallest part of the bore (if it was only honed) use a piston top to push the new ring down into the cyl. The least worn area is within two finger widths of the bottom. The ring should be square with the cyl, not tipped. Ring gap is checked with feeler gauges at the gap. If too tight, they must be widened to spec. If gap is to be .005, and measures .002, use a dremel tool to remove just that amount. Too wide causes drastic leaking. The second isue is ring land wear. the ring groove should be square and have parallel sides. Stick a ring into the groove from the outside (like putting a quarter into a vending machine) and see that it has very little play up and down. If the outer rim of the test ring can move more than about 1/8 " the groove needs to be repaired (possible) or piston replaced. #3 I use chrome rings they last. JimN
Home
| Forums
Today's Featured Article -
Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
