Re: died h still no spark
Posted by El Toro on April 07, 2005 at 17:27:27 from (152.163.101.13):
In Reply to: died h still no spark posted by baler46 on April 07, 2005 at 16:27:19:
I would replace the condenser, then see if the tractor will start. Have you checked the rotor
for any residue? Clean the metal on the rotor that contacts the cap. Check for voltage at the coil with switch on if this is battery ignition.
Your switch could be the defective. Check for voltage at the switch then the coil. Hal
Post a Followup
