Re: SAE A or B bolt pattern on H4 magneto?
Posted by David in UT on April 07, 2005 at 19:51:51 from (208.15.63.195):
In Reply to: Re: SAE A or B bolt pattern on H4 magneto? posted by farmalldan on April 07, 2005 at 10:45:15:
Thanks Dan!
You're right on track with me -- although the guys at the hydraulic shop that checked out the M&W pump thought they could get me piggyback pump for somewhere around 300 bucks...that may not be the case given your research. I'll have to poke around on that a bit more to see how outta whack my cost expectations might be. I've got a couple of buddies that could fabricate the timing gear cover and slotted drive coupling for, so I think I've got that covered.
In any case, thanks for the input. If I get this all working for something close to the $550 for a stock pump, I'll post the details.
- David
Post a Followup
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
