Re: need advice on rewiring C lights
Posted by Paul Shuler on April 07, 2005 at 21:32:34 from (170.29.5.10):
In Reply to: need advice on rewiring C lights posted by greensboro george on April 07, 2005 at 12:41:38:
I did mine like Peabody said. Except I use a section of heavy string and ran it all the way through the pipe from side to side. Then fished it down with a wire with a small hook on the end. Then just taped my wire to the string and pulled it all through. It took a little time but now hard. Did have to dig a lot of crap out befor my sting and wire would go easy.
Post a Followup
