Re: I Don't Get It
Posted by John A. on April 08, 2005 at 21:51:12 from (65.161.170.34):
In Reply to: I Don't Get It posted by Allan in NE on April 08, 2005 at 16:29:44:
Allan, Back in the panhandle when I was there My cousins and I would tag team our largest tractor (a JD-8640 w/ a 35 ft Big G double-offset) in-a-Bind Times. We would take turns plowing for 6 hr each/da. While the other two did the normal work in theie off 12 hrs. hence all the plowing got done an everybody land and all regular work got done too. It isn't hard to put 100hr a week on a tractor. At a 100hr /week it doesn't talk long to rack up the hr.
As for brakes....We farmed in throughs, not in a Land fashion so turns are not a problem!! No brake troubles. For what it is worth...
Later,
John A.
Post a Followup
