Re: I Don't Get It
Posted by Hugh MacKay on April 09, 2005 at 03:25:51 from (216.208.58.133):
In Reply to: Re: I Don't Get It posted by oliverfan on April 08, 2005 at 21:09:54:
oliverfan: Pulling those pins and letting the drawbar swing worked fine on 40, 50, 60 and 70 hp tractors pulling up to 13' cultivator. You try that with 150 hp on 26' cultivator, the results will be expensive. I've seen a tractor with side broke out of rear end casting, from just such actions.
Post a Followup
