Farmall Tractors Discussion Board
H Farmall Carb Woes...
Posted by Jerry on December 07, 1999 at 19:21:55 from (207.177.24.49):
I rebuilt an H carb that had the float level all screwed up and leaked gas frequently. The carb went together fine and the tractor started right off. I felt very proud of the rebuild job, but now the same thing is happening. The carb leaks gas bad when the fuel valve is open. I took off the carb bowl and gently moved the float which seemed to work fine. It still leaks like the float is stuck in the "down" (open) position. Do H carbs have a reputation for this problem? Any suggestions?
Post A Followup
: Re: H Farmall Carb Woes...
