Farmall Tractors Discussion Board
Re: H Farmall Carb Woes...
Posted by The Red on December 08, 1999 at 03:07:38 from (12.75.196.167):
In Reply to: H Farmall Carb Woes... posted by Jerry on December 07, 1999 at 19:21:55:
Jerry I am assuming that when you rebuilt the carb you installed a new float needle and seat? When the needle is closed, the back of the float assembly should be parallel with the upper carburetor assembly. Sounds like that needle isn't closing. It's possible your float is not floating. check for leaks.
Post A Followup
: Re: Re: H Farmall Carb Woes...
