Re: Farmall A Coil
Posted by Bob M on April 11, 2005 at 08:32:43 from (151.190.254.106):
In Reply to: Farmall A Coil posted by MattMO on April 11, 2005 at 07:13:15:
Matt - Any internally ballasted (so called "12 volt") will work. Just ask for a generic 12 volt ignition coil. Or you can get a generic, unballasted (6 volt) coil and add your own ballast resistor.
However I gotta agree with MagMan - if you are able get that magneto system working and dispense with the coil ignition system altogether!
Post a Followup
