Re: Speedi-Sleeve??
Posted by Haas on April 11, 2005 at 18:23:22 from (12.65.43.218):
In Reply to: Speedi-Sleeve?? posted by Jim VA on April 11, 2005 at 09:11:15:
There should be a Motion Industies bearing house around you someplace. Take your pump there and as others said, they will measure it and get you the Speedy sleeve you need. They can also probably get you the shaft seal for the pump. I've not used a Speedi spleeve for this application, but did use one for the main steering gear lower seal on a Super C. Holds oil now with no leaks.
Post a Followup
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
