Re: slow drip on my carburator?
Posted by riverbend on April 11, 2005 at 19:07:50 from (208.160.34.44):
In Reply to: Re: slow drip on my carburator? posted by lekander883 on April 10, 2005 at 20:14:38:
Try tightening the packing nut. When you have done that, you might need a screwdriver to turn the main jet adjustment screw. If that does not help, you will need a new packing.
I am not sure if IH still has them. If not, they come in the TISCO complete kits. If the packing is in the basic kit, it will be a little cheaper.
When you replace the packing, it is traditional to get a crumb of the old packing that blocks the fixed part of the jet. When compressed air does not clear it, carefully try to push it through with a soft copper wire. Then take the carb off again and blow it out from the inside.
Post a Followup
