Re: octane for farmall H? 87, 89, 92
Posted by MagMan on April 12, 2005 at 09:43:09 from (152.163.101.13):
In Reply to: octane for farmall H? 87, 89, 92 posted by arod on April 12, 2005 at 09:19:43:
Hi Arod I beleve the tractors were made to run on low octain . The higher the octain the cooler they will run.I beleve with the high compression kit it would run a little better with higher octain but I think for what you did you would be waisting your money running anything over 87. I have not ever ran a dipstick I just fill her up untill she works good and if she gets slow I ad a quart. I dont think you would hurt it to over fill her I will measure a dip stick and let you know so you can make one out of wire to check it with. JON
Post a Followup
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
