Re: Super C hitch
Posted by George 2 on April 12, 2005 at 16:30:08 from (216.46.141.114):
In Reply to: Re: Super C hitch posted by Huh? on April 12, 2005 at 07:35:03:
You know it is very easy to make a 3 point hitch for a Super c if you have the plow hitch rockshaft. Mine has a C214 plow with it and when the plow is off all you have to make is brackets that bolt onto the side of the drawbar assembly. Then you buy a set of lower hitch arms from a parted out 504 and a set of lift arms from the 504. Add a cross steel plate to the plow hitch rockshaft for the third link mounting and you have a 3 point lifted by the Touch Control hydraulic lever. I am intending to build this setup for mine and it will use over 90% IH parts.
Post a Followup
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
