Re: True Confessions, Join In
Posted by caseyc on April 12, 2005 at 17:06:39 from (66.115.192.142):
In Reply to: True Confessions, Join In posted by Michael Soldan on April 12, 2005 at 15:17:51:
well as some of you know i put a headgasket in my 706 two winters ago. last winter it went to missing again and rather then check plugs and wires i went straight to a compression test because that's how i found the problem last time. #5 was low so i parked it till warmer weather and froze my butt off on the 766 all winter. (706 has a cab and 766 does not) come the first nice day in march i decided to tear into it. just to make sure #5 was the bad one i pulled the plug wire...there was a big change. after another min of pulling wires #1 ended up being the dead cylinder. swapped plugs to anothe hole and the miss followed. put all new plugs in and she runs great!!! definetly not my shining moment for being a young but seasoned mechanic.
casey in SD
Post a Followup
