Re: Second Time Post For Serial # Location H Block
Posted by DWV on April 13, 2005 at 08:29:33 from (152.163.101.13):
In Reply to: Second Time Post For Serial # Location H Block posted by MAGMAN on April 13, 2005 at 05:42:59:
Magman need more info,what is casting # on block,
date code and is dip stick hole drilled with a plug or a dip stick in it.On a H most all block serial # match tractor serial #.
Post a Followup
