Re: CaseIH 885 brakes
Posted by Bernard le mécano on April 14, 2005 at 04:18:27 from (207.134.221.208):
In Reply to: Re: CaseIH 885 brakes posted by DanTo on April 13, 2005 at 20:22:10:
Hi Dan, try to bleed again and check tomorrow if the right brake is OK. When you press one pedal at the time, you may have a better feel. When you press the both pedal, the equaliser valve split the oil to the both brake, if it have a leak in one piston, both pedal goes donw. It's not a hard job to change the O rings with a XL cab. The support is easy to remove and you have enough room to make the job. When you bleed, pinch with a Wise-Grip, the return hose, from the master cylinder (the big one) and run the engine to 1500 RPM. Place 2 small pipe on the open bleeders and put those pipes in the hole where you put HY-Tran. Press one pedal in the half and hold it, press the other all the way down slowly, 10 time. Make that to the other side, the close the bleeders the stop the engine and remove the pliers. Bernard le mécano
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
