Re: in and out/sideways slop on F-20 break drum sh
Posted by Nebraska Cowman on April 16, 2005 at 16:49:09 from (65.165.16.16):
In Reply to: in and out/sideways slop on F-20 break drum shaft posted by Okla Kansan on April 16, 2005 at 13:58:58:
pretty common to find the drum loose. lots of them have a special locking nut to help keep them tight. IH used a lot of felt seals. Most anything would work. You can still buy rope packing. But it sounds like you may have a bearing problem too. Once you get the retainer off the whole shaft should slide right out. Can't remember I think the bearing stays in the housing and you may have to use some kind of puller. i am writing from memory and a poor memory at that. But I do have a lot of F20s around and should have parts if you need them.
Post a Followup
