Re: pully
Posted by captaink on April 18, 2005 at 16:45:43 from (66.115.214.56):
In Reply to: pully posted by hw1227 on April 18, 2005 at 15:03:42:
This is going to be quick.
To change the fan belt, the top pulley is split with the front half threaded to move in and out. There is a set screw in the hub that “locks” the pulley half in place. This is how the belt is tensioned. If you turn the front half counter clockwise (as viewed from the radiator) the belt will loosen and you will be able to remove it.
Be careful as this is cast iron and will break easily. I'd oil it up good and let it set overnight at least before I'd go to work on it.
Good luck :>)
Post a Followup
