B-275 diesel utility tractor, good tractor??
Posted by Mark L. on April 18, 2005 at 18:20:34 from (172.168.6.189):
Hi folks. I found a B275 Diesel Utility tractor today. The serial number is in the 198xx range. It has a wide front end, hydraulic hitch, hydraulic remotes, and what seems like a two stage clutch? Also IPTO with H-L. The price on the tractor is $2200. It starts right up, but blows out a blue gray smoke? Front end good shape, no welds, but will need some tie rod ends soon. Play in the steering box also. I am looking for a smaller utility tractor to help move around my non-running rescue tractors, any info would help. Good tractor? How many made? Thanks again.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
