Re: International / Harvester dealer?
Posted by El Toro on April 19, 2005 at 19:21:15 from (152.163.101.13):
In Reply to: International / Harvester dealer? posted by Chris in Lakefield Ontari on April 19, 2005 at 16:52:07:
You need to post the SN of the tractor and someone
can probably determine the year.
Follow your battery cables, one goes to ground and the other to the starter. Some tractor's have the ground on the starter too and the other
cable may connect to a solenoid on the starter.
That is where battery voltage is supplied to your
starter. Will the engine crank using the starter? The battery may need charging or replaced. Hal
Post a Followup
