Re: knock in engine 300 utility HELP??
Posted by Sloroll on April 20, 2005 at 09:22:39 from (69.66.43.59):
In Reply to: knock in engine 300 utility HELP?? posted by Amishbob on April 20, 2005 at 08:26:48:
Not to panic yet. Those 300U pans fit tight. With a little wear the crank will shift fore and aft allowing the rods to strike the pan. It is pretty easy to pull the pan (check for hit marks) and roll in new rod and main bearings. I've done it in the field with the plow in the furrow. I was much thinner then though and it was fun because I was play farming.
Post a Followup
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
