Re: Old Age, Bad Memory, or What?
Posted by captaink on April 20, 2005 at 13:53:27 from (66.115.214.56):
In Reply to: Re: Old Age, Bad Memory, or What? posted by Allan in NE on April 20, 2005 at 13:17:49:
Allen,
On the 966, when you pull the hydraulic lever for the remote cylinder up and back, the pressure should come out the top port on the coupler. If you push it ahead and down, the pressure comes out the bottom port. I have run one for 30 years, take it for what it’s worth…
If you are really set on having the bottom one be the lifting pressure, I suppose you could swap the lines…
Post a Followup
