Re: bearing size
Posted by El Toro on April 20, 2005 at 18:49:33 from (152.163.101.13):
In Reply to: bearing size posted by Thomas Lundy on April 20, 2005 at 17:22:01:
I think you should check the crankshaft end play.
My manual has the end play from.004" to .008".
This can be checked easily with a dial indicator.
The end play is determined by the rear main bearing. Hal
Post a Followup
