Re: Singing 'C'
Posted by Dennis Gauge on April 20, 2005 at 19:09:12 from (64.232.65.70):
In Reply to: Singing 'C' posted by Dixieland on April 20, 2005 at 18:53:37:
The pump is whining because the oil is being forced through the system, probably past the relief valve, because it"s normal "neutral" path is blocked.
See, when the hydraulics aren"t being used, the oil should flow straight through the center of the system right back to the reservoir. Hence the term "open center."
Have you moved the touch control levers to see if the problem goes away?
Post a Followup
