Re: B275 Steering Q's
Posted by Michael Soldan on April 23, 2005 at 17:50:30 from (66.203.172.221):
In Reply to: B275 Steering Q's posted by Derek Broerse on April 23, 2005 at 11:39:13:
Derek, I think your description of that center hole being worn elongated would allow the axle to rotate enough to jam your steering, also check tire pressure. I discovered a 15 and 16" tire on my B250 when I got it home, steers good with two 16"s now. Remove the grease zirks and make sure they are not plugged, then try to get as much as you can into the spindles. Tow in can restrict your steering when the weight of the tractor is on the wheels. My B250 manual suggests that toe in can only be set when the steering is in the neutral position and the front axle is not tilted. I would take from that, that your problem is in the axle and the elongated hole. Measure from the front, lip of the rim at hub height across to the other rim lip , then measure the rear rim lip to rear rim lip. The rear measurement should be 1/4th to 3/8ths inch wider than the front measurment. Also the tow-in should be adjusted evenly between both drag links to set it properly. As to the hole that is worn, I would center the axle and tighten the axle bolts. If it was mine I would drill a new hole and pin it , but a welding shop could weld up the elongated hole and then drill a new hole where it originally was. I think that would fix your problem. As to the loose steering box that would make slop in the steering but shouldn't make it stiff...good luck from Mike in Exeter Ontario
Home
| Forums
Today's Featured Article -
Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
