Re: 3 pt. hitch woodsplitter, on an M
Posted by Dixieland on April 24, 2005 at 16:17:14 from (207.119.211.26):
In Reply to: 3 pt. hitch woodsplitter, on an M posted by brianh on April 24, 2005 at 14:16:10:
Hi Brian...I am in the process of finding a spool valve for the same purpose. I got some feed back on my questions and one suggested not to over fill the belly pump...6 quarts...or that would happen untill it reached the proper level. Drain the pump and measure 6 quarts. If that ain't it I need to know the problem before I install my spool valve.
Post a Followup
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
