Re: 706 Head Gasket
Posted by ChadS on April 25, 2005 at 07:34:57 from (66.228.96.160):
In Reply to: 706 Head Gasket posted by FARMALLION on April 25, 2005 at 05:30:10:
I rebuilt a 706 gasser that did the same thing ter an overhaul, I retorqued the head, and it seemed to solve it. If its not been apart, and it gets worse, youll take the chance of warping the head from the heat, and pressure escaping. Sounds like you mite think about pulling it apart. I use copper coat spray on all headgaskets, whether it requires it or not,, and it helps quite a bit in cases like this. Hope this helps,,, ChadS
Post a Followup
