Super C throttle/ Governor
Posted by Andrew Z on April 25, 2005 at 14:02:24 from (137.99.195.109):
On my Super C the governor will respond good when the tractor is put under load. However it will not come back down in RPM's after the load is off it will be stuck at a higer RPM than the throttle was set at. I a ready replaced the bearing in the governor. I think that the governor spring is tired? Could this cause this problem??
Thanks
Andrew
Post a Followup
