Farmall A 1-Bottom mounting??
Posted by WI jake on April 25, 2005 at 14:31:30 from (69.179.51.72):
I have a 1945 Farmall A with most, if not all of the parts to hook up the one bottom plow with manual lift lever. I was wondering if anyone out there had a diagram or pictures of a mounted one bottom plow, so that I can make sure I am doing it right. Thanks, Jacob
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
